Is turning off STP globally (on all ports including LAG) as simple as unchecking the Enable box at top left of STP tab. Or do we need to disable it on all switch ports also?
Khan
Turning off STP globally
- ozmetaldrummer
- Been thanked: 210 times
Re: Turning off STP globally
Yes simply uncheck the box on the top and it will globally disable STP. You do not have to uncheck individual ports.
- ozmetaldrummer
Thanks bud
