Hi to all!
This is my first time using netonix switches. I bought some WS-12-250-dc, il there a video or schema on how to proceed to hook them to de battery bank?
Reading the notice that can with the switch made me scare to use it!!! There's not a lot of documentation on how to use them or hook them.
I mean, best practices, witch cable to hook first, positive/negative, where do i put the inline fuse?
I also bought minn kota battery charger like sirhc recommend in this post, (https://forum.netonix.com/viewtopic.php?f=17&t=3378&start=10&sid=49c16bab02d40bfb494a7eb6872b774e#p22255)
I have 2 12v 110AH enerwatt agm battery.
I plan to put the switch on to of the elevator, at 100feet up, so i think i will use 2/12 soow cable to connect the switch. there will be max 150watt of load.
how should i do the ground connection? i was thinking to install a ground rod and hook it to the elevator and ground the switch to the elevator too. is this correct?
Where i can download the user guide for this switch?
Thanks in advance to all of you that will help me!!
Patrick
First time user
1 post
