Hi Guys,
Does anyone know if it is possible to show the firmware version only on command line?
I know we can see it with show status, however that returns loads of unique information.
I would like to run a command via Unimus to quickly identify on around 1000 switches which ones are on which firmware. Ideally I dont want to have to look at each result 1 by 1.
We have found an issues with 1.5.5 that has caused instability on a number of switches and would like to find out quickly which other switches are currently running it and downgrade them to 1.5.4.
Thanks guys
Show firmware version on command line
- ukzerosniper
- Been thanked: 210 times
Re: Show firmware version on command line
You can easily do that with the Netonix Manager to monitor all of these switches at once to see their firmware versions and upgrade/downgrade as necessary.
Could you provide some more details on the problem you're seeing with 1.5.5?
Omniflux - Experienced Member
- Has thanked: 5 times
- Been thanked: 33 times
ukzerosniper wrote:Does anyone know if it is possible to show the firmware version only on command line?
I don't know a single command you can use. Can you issue multiple commands?
- Code: Select all
Z-133 PoE Switch# cmdline
BusyBox v1.19.4 (2018-06-01 19:38:44 EDT) built-in shell (ash)
admin@Z-133_PoE_Switch:/www# cat version.txt && exit
1.5.5
Z-133 PoE Switch#
- ukzerosniper
Stephen wrote:You can easily do that with the Netonix Manager to monitor all of these switches at once to see their firmware versions and upgrade/downgrade as necessary.
We found that one switch simply wouldnt pass traffic correctly across its VLANS. It seemed that it was generating a huge amount of ARP traffic. It was really unusual..
We found that another switch could not pass VLAN traffic when running QinQ to use the switch as a midspan POE injector.
- ukzerosniper
Omniflux wrote:ukzerosniper wrote:Does anyone know if it is possible to show the firmware version only on command line?
- Code: Select all
1.5.5
Z-133 PoE Switch#
This looks interesting, we could certainly try this. Thanks
- ukzerosniper
Great, I will have a look, I didn't realize this was a thing!
- ukzerosniper
ukzerosniper wrote:Omniflux wrote:ukzerosniper wrote:Does anyone know if it is possible to show the firmware version only on command line?
- Code: Select all
1.5.5
Z-133 PoE Switch#
Just to update, this worked perfectly
