-48 Systems and DC Switches
ginovilla
Been thanked: 5 times
Wed Apr 08, 2015 8:39 pm
Any feedback on this combination? We are looking into using the DC Switches in telco cabinets with existing -48, is the DC switch floating ground?
Been thanked: 159 times
Re: -48 Systems and DC Switches
Wed Apr 08, 2015 9:24 pm
sorry, current to be released soon DC switch is not a floating ground.
Tue Apr 14, 2015 8:33 am
Sorry, i didn't respond correctly to the question about floating inputs.
The correct answer is yes, our switch circuitry is floating in regards to the chassis. So if you h ave a 48 or -48 volt power system, it will work.
You just have to make sure of course that you hook up the -48 v to our power ground input (the black terminal).
The only thing hooked up to our "chassis" is the RJ45 & SFP shield's, along with the grounding lug on the front or rear panel.
ginovilla
Wed Apr 15, 2015 12:07 pm
so it should work!
