Hi guys.
I tried doing a fan swap but decided against it due to the system logging fan errors.
Is there a way I can control the fan or change the curves? I'd rather it run at 2000rpm 24/7 than 4000rpm. I will be throwing a 140mm fan ontop regardless to help with the flow, though the ambient temperature is under 24*c at all times. I can't find any options, but I am willing to dive into the shell.
Also does the AC model have POE "turning off" at a specific temperature as I've heard the DC verison does? I do not see priority options in the power tab.
WS-8-150-AC Fan control?
- nahventure
- nahventure
Re: WS-8-150-AC Fan control?
no replies: the solution? slap a big 140mm silent fan on the top and you're good to go. it'll complain about no fan, but I assure you a 140 mm fan covering everything will more than suffice for this little fella.
