Currently powering the device in subject line with this Cambium Networks - N000900L001C
Is it possible to power this device directly from a Netonix?
Powering a Cambium Networks - C009045B001A
zrob_12 - Member
zrob_12 - Member
- BenJeffery
Re: Powering a Cambium Networks - C009045B001A
To power a PMP450i 900MHz subscriber unit or the PTP450i 900MHz with a Netonix, you use 24v PoE mode and you have to change the pinout so that pins 4,5 are swapped with pins 7,8.
For the PMP450i AP, you can use 48v PoE mode without modifying the pinout. To get GPS sync, you'll have to use something like a Packetflux Syncbox Auxiliary.
