We have a large network with many Netonix switches.
Trying to limit the number of broadcast/multicast packets in the network, we found that the Netonixs send A LOT of IPv6 "Multicast Listener Report" (more then 25% of the broadcast/multicast traffic is done of these).
Is there any reason for this behavior if the switch don't even have an IPv6 address set (IPv6 section is disabled)???
Is there a way to stop them?
Thanks.
Why IPv6 "Multicast Listener Report" packets are sent?
- Been thanked: 210 times
Re: Why IPv6 "Multicast Listener Report" packets are sent?
That is odd. Multicast Listener Discovery is of course built into ICMPv6 so if you have IPv6 disabled completely it is a bit odd that you're seeing those messages.
Please post output from the following command:
- Code: Select all
cmd
ip addr
giannici - Member
OK, here is the output:
This one is a WS-12-250-AC with 1.5.5, but the same occurs with different models and firmwares.
I confirm that the "IPv6" section of config is DISABLED.
- Code: Select all
Cammarata# cmd
BusyBox v1.19.4 (2018-06-01 19:38:44 EDT) built-in shell (ash)
root@Cammarata:/www# ip addr
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 16436 qdisc noqueue
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 brd 127.255.255.255 scope host lo
inet6 ::1/128 scope host
valid_lft forever preferred_lft forever
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast qlen 1000
link/ether ec:13:b2:61:3f:e0 brd ff:ff:ff:ff:ff:ff
inet 10.10.252.127/16 brd 10.10.255.255 scope global eth0
inet6 fe80::ee13:b2ff:fe61:3fe0/64 scope link
giannici - Member
About broadcasts, I noticed a lot of Gratuitous ARPs too. When are they sent?
Do you mind sending me a pcap file that has the Multicast Listener Report packets captured? I want to compare it to mine to see if there are any difference's.
Yes the gratuitous arp's are VERY MUCH SO on purpose.
It is a bug fix mentioned here:
"- Boot up now performs a gratuitous ARP broadcast, which prevents the scenario where upon a warm or cold boot (aka firmware upgrade, etc) where loss of connectivity
to the switch's management site or ssh access occurs even if sometimes otherwise the switch is operating. "
giannici - Member
Stephen wrote:Do you mind sending me a pcap file that has the Multicast Listener Report packets captured? I want to compare it to mine to see if there are any difference's.
There are A LOT of gratuitous arps, they are NOT sent only on boot!
I'll send you a pcap later...
Thank you giannici for sending the pcap file. I'll start examining it. During experiments we found that change's in the network can cause a loss of connectivity to a switch if the gratuitous arp's are not being sent at an interval. I can of course slow them down a but any decrease mean's an increase in waiting for access back to the switch in such a case as a topology change.
I will take a look at the pcap file and see if I can trace down why MTD is active when IPv6 is disabled.
giannici - Member
Stephen wrote:Thank you giannici for sending the pcap file. I'll start examining it. During experiments we found that change's in the network can cause a loss of connectivity to a switch if the gratuitous arp's are not being sent at an interval. I can of course slow them down a but any decrease mean's an increase in waiting for access back to the switch in such a case as a topology change.
Maybe an option could be added in the config for those that need to enable/disable these periodic gratuitous ARPs (except for those on boot that can be always useful and have almost no weight).
Not a bad thought at all.
giannici - Member
Hi.
Any news on this?
When will a new firmware be released?
Any news on this?
