Question on STP
astuke
Question on STP
Fri Dec 20, 2019 9:56 am
We have a Powerbeam to Powerbeam bridge out to one custom. They have a single router on their end, I'm getting these all of the sudden and our pings keep dropping
Dec 19 19:55:14 STP: msti 0 set port 12 to discarding
Dec 19 19:55:14 STP: msti 0 set port 12 to learning
Dec 19 19:55:14 STP: msti 0 set port 12 to forwarding
Dec 19 21:07:56 STP: msti 0 set port 12 to discarding
Dec 19 21:07:56 STP: msti 0 set port 12 to learning
Dec 19 21:07:56 STP: msti 0 set port 12 to forwarding
Dec 19 21:08:17 STP: msti 0 set port 12 to discarding
Dec 19 21:08:17 STP: msti 0 set port 12 to learning
Dec 19 21:08:17 STP: msti 0 set port 12 to forwarding
Dec 19 21:28:57 STP: msti 0 set port 12 to discarding
Dec 19 21:28:57 STP: msti 0 set port 12 to learning
Dec 19 21:28:57 STP: msti 0 set port 12 to forwarding
Dec 19 22:38:52 STP: msti 0 set port 12 to discarding
Dec 19 22:38:52 STP: msti 0 set port 12 to learning
Dec 19 22:38:52 STP: msti 0 set port 12 to forwarding
Dec 20 00:14:09 STP: msti 0 set port 14 to discarding
Dec 20 00:14:14 STP: msti 0 set port 14 to learning
Dec 20 00:14:14 STP: msti 0 set port 14 to forwarding
Dec 20 07:11:05 STP: msti 0 set port 12 to discarding
Dec 20 07:11:05 STP: msti 0 set port 12 to learning
Dec 20 07:11:05 STP: msti 0 set port 12 to forwarding
Should I just disable STP for that port?
Should STP be disabled our our Point to multipoint AP's also?
Re: Question on STP
Wed Dec 25, 2019 12:09 am
You could try but I'm under impression it's a port issue (down / up).
STP should never be enable on port facing customers, only on backbone and backhaul port.
