Helllo
I am about 50% output, and my power supply input current at 52V is 2.5amps ... perfect..
If I change to a 24V battery bank, will that mean my power supply input current would jump to 5amps? (the max the bar graph shows)
so powering this switch from 24v would limit its output to 125w?
Rhys
WS-12-250-DC Input current
- Rhys Cuff
Dave - Employee
- Been thanked: 159 times
Re: WS-12-250-DC Input current
Rhys
At 24 volts input voltage you still have the full 250 watts output power, and you will use about 12 amps at input.
- Rhys Cuff
I noticed the input current bar graph tops out at 5 amps, that’s what threw me.
Thanks again
Rhys
Thanks again
Rhys
Dave - Employee
input current graph limit will change depending on input voltage.
- Rhys Cuff
