Can one of y'all give me the size/threads for the 4 little black screws that hold the cover on the WS-6-MINI? I got a new one in today and was working on mounting it when I noticed that one of the screws was stripped out from the factory. Took me a bit to get it out, and I'd like to replace the screw but I can't find any documentation (CAD drawings, etc) that list the exact size screw I need.
Any help is appreciated. Thanks!
WS-6-MINI, screw size?
Re: WS-6-MINI, screw size?
The screws are whats called undercut heads so they are more flush when screwed in so I doubt you will be able to find them.
m3 x 0.5d3 hss
so the mini has 4 screws but only 2 hold the lid on the other 2 simply hold the corners flush.
m3 x 0.5d3 hss
jpaine619 - Member
- Has thanked: 26 times
- Been thanked: 19 times
Well, I reckon it doesn't have to be perfect. I'll use the replacement screw on the top where it won't interfere with my mounting, if it doesn't sit exactly flush.
Any chance y'all could get some of the CAD drawings up for these units? Info like that is useful when making minor repairs.
Also, while we're at it. Any chance on getting some downloadable documentation in the future? A User Manual that explains all the functions, icons, indicators, etc would be useful. I know there's info here in the forums but something a bit more formal is long overdue. I was digging around the other day trying to get an explanation of all of the various permutations of the PORTS graphs (outer color, inner color, etc) and it took way longer than reasonable.
jpaine619 - Member
sirhc wrote:The screws are whats called undercut heads so they are more flush when screwed in so I doubt you will be able to find them.
Yeah. It took me about 5 mins to track them down :)
https://www.amazon.com/gp/product/B075C6C4YR/
That kit had the EXACT screws. Flush fit and all. 100% identical. Never question my search skills.
