Switch reboots when making a dns change
- md1man42
I am updating dns ip addresses and when I save/apply there is no warning but the switch appears to do a soft boot. I have made the change on switches running 1.4.9 and 1.5.2 I see nothing in 1.5.3 or 1.5.4 that addresses this. Logs show nothing concerning the dns change only root port changes. It seems that I should be able to update DNS without causing a brief outage for customers. I would like to make a feature request that would allow this in the future.
- Been thanked: 210 times
Re: Switch reboots when making a dns change
I will investigate this situation. Does this happen all the time you make a DNS change or is it sporadic?
- md1man42
I apparently was mistaken that it does not log the dns change it clearly does, here is the log This occurs everytime
Sep 9 10:55:36 UI: Configuration changed by admin ()
Sep 9 10:55:36 UI: Syslog_Host: changed from ' to ''
Sep 9 10:55:47 UI: Configuration auto backup successful
Sep 9 10:56:04 UI: Configuration changed by admin ()
Sep 9 10:56:04 UI: IPv4_Primary_DNS: changed from '64.7.172.12' to '64.7.161.12'
Sep 9 10:56:08 admin: removing lan (eth0.4) from firewall zone lan
Sep 9 10:56:12 UI: Error occured during TFTP auto backup: tftp: bad address ''
Sep 9 10:56:15 admin: adding lan (eth0.4) to firewall zone lan
Sep 9 10:56:16 system: starting ntpclient
Sep 9 10:56:46 STP: set port 1 to discarding
Sep 9 10:56:46 STP: set port 2 to discarding
Sep 9 10:56:46 STP: MSTI0: New root on port 2, root path cost is 520
Sep 9 10:56:46 STP: set port 2 to learning
Sep 9 10:56:46 STP: set port 2 to forwarding
Sep 9 10:56:46 STP: set port 1 to learning
Sep 9 10:56:46 STP: set port 1 to forwarding
