Netonix Manager does not start
Seb65
Fri Aug 09, 2019 8:24 am
Hello,
I have a new server with Debian 10 + UNMS 1.0.0b9.
I just installed netonix-manager_1.0.15_all.deb but this one does not work.
root@unms:~# service netonix-manager status
● netonix-manager.service - LSB: Start daemon at boot time
Loaded: loaded (/etc/init.d/netonix-manager; generated)
Active: active (running) since Fri 2019-08-09 14:13:28 CEST; 4min 24s ago
Docs: man:systemd-sysv-generator(8)
Process: 495 ExecStart=/etc/init.d/netonix-manager start (code=exited, status=0/SUCCESS)
Tasks: 14 (limit: 4915)
Memory: 105.8M
CGroup: /system.slice/netonix-manager.service
├─ 507 /usr/bin/nodejs bootloader.js
└─5738 nodejs app.js
août 09 14:13:28 unms systemd[1]: Starting LSB: Start daemon at boot time...
août 09 14:13:28 unms systemd[1]: Started LSB: Start daemon at boot time.
root@unms:~# netstat -an | grep 3443
root@unms:~#
root@unms:~# node --version
v10.15.2
root@unms:~# nodejs --version
v10.15.2
root@unms:~#
An idea of ​​the problem :idea:
Been thanked: 210 times
Re: Netonix Manager does not start
Fri Aug 09, 2019 11:36 am
I'm not extremely familiar with this distro of linux. However, sometimes the environment variable isn't set correctly, you can test that with this:
Code: Select all
export NODE_ENV=production
node bootloader.js
Also, running it directly might tell us more about what's happening.
It seems like it's implying that it's been active for awhile. Did it work before and suddenly stop?
Seb65
Sun Aug 11, 2019 5:01 am
I have errors :
Code: Select all
root@unms:/opt/netonix-manager# node bootloader.js
starting child process
{ Error: Cannot find module '../build/Release/bson'
 at Function.Module._resolveFilename (internal/modules/cjs/loader.js:581:15)
 at Function.Module._load (internal/modules/cjs/loader.js:507:25)
 at Module.require (internal/modules/cjs/loader.js:637:17)
 at require (internal/modules/cjs/helpers.js:22:18)
 at Object.<anonymous> (/opt/netonix-manager/node_modules/bson/ext/index.js:15:10)
 at Module._compile (internal/modules/cjs/loader.js:689:30)
 at Object.Module._extensions..js (internal/modules/cjs/loader.js:700:10)
 at Module.load (internal/modules/cjs/loader.js:599:32)
 at tryModuleLoad (internal/modules/cjs/loader.js:538:12)
 at Function.Module._load (internal/modules/cjs/loader.js:530:3) code: 'MODULE_NOT_FOUND' }
process exit code 1
process exit code 1
process exit code 1
The manager never worked after installation.
Mon Aug 12, 2019 12:33 pm
Did you run the command:
Code: Select all
Before you started the bootloader.js?
Seb65
Mon Aug 12, 2019 2:26 pm
Yes I run this command and get errors...
Mon Aug 12, 2019 3:12 pm
OK, let's check to see where node is installed at.
Let me know what the results for these command's are:
Code: Select all
whereis node
and
Code: Select all
whereis nodejs
Seb65
Tue Aug 13, 2019 1:38 am
Code: Select all
root@unms:~# whereis node
node: /usr/bin/node /usr/share/man/man1/node.1.gz
root@unms:~# whereis nodejs
nodejs: /usr/bin/nodejs /usr/lib/nodejs /usr/share/man/man1/nodejs.1.gz
root@unms:~#
Tue Aug 13, 2019 4:58 am
OK I just wanted to make sure that bootloader.js could find your node install's.
It looks for nodejs first, and since you have both installed when we ran the bootloader with 'node' first, it found the 'nodejs' and attempted to open the main nm app with a different binary then what started it.
What happens if you run:
Code: Select all
Seb65
Tue Aug 13, 2019 11:36 am
Code: Select all
root@unms:~# cd /opt/netonix-manager/
root@unms:/opt/netonix-manager# ls
app.js           crash.log             node_modules  start.sh  version.txt
bootloader.js    models                private.key   stop.sh   views
certificate.pem  netonix-manager.init  public        util.js
root@unms:/opt/netonix-manager# export NODE_ENV=production
root@unms:/opt/netonix-manager# nodejs bootloader.js
    at Object.<anonymous> (/opt/netonix-manager/node_modules/bson/ext/index.js:1        5:10)
    at Function.Module._load (internal/modules/cjs/loader.js:530:3) code: 'MODUL        E_NOT_FOUND' }
process exit code 1
process exit code 1
^C
Seb65
Tue Aug 20, 2019 6:49 am
An idea of problem ? A package is missing ?
