We have an ES-24-400B that for some time now shows the following message in the log Aug 5 11:43:27 SFP: FAULT on SFP 2, resetting ... every two seconds
We have reset the switch, updated the firmware and disabled the port but the problem persists.
There is a solution
WS-24-400B log fault SFP: FAULT on SFP 2, resetting...
smaicas - Member
- Been thanked: 210 times
Re: WS-24-400B log fault SFP: FAULT on SFP 2, resetting...
Best place to start is making sure you are on the latest firmware (1.5.3) and if that doesn't work (or if you are already on the latest) Try a different SFP module.
Here is a list of repoted compatible/incompatible SFP module's
smaicas - Member
Firmaware is (1.5.3) and any SFP muodele is connected
If you tried other SFP modules from the list of known working modules then maybe a hardware issues.
Most likely can not be repaired and since the WS-24-400B was EOL 3 years ago we no longer have replacement boards.
Your welcome to RMA it and if we can not repair it you can always abandon it.
