DC 12 port switch
amishgenius - Associate
- Has thanked: 44 times
- Been thanked: 45 times
DC 12 port switch
Paging @mhoppes...which closet does Chris hide his prototypes? I need to slither in there and make one of those 12 port DC POE switches with SFP cage follow me out the door.
- Has thanked: 188 times
- Been thanked: 64 times
Re: DC 12 port switch
@amishgenius,
To find the switches, you will need to go to the second basement of Chris' warehouse. At the bottom of the stairs you will find a sturdy locked door. If you can get past the door, you will see a funky old elevator. Take the elevator ALL the way down. I am pretty sure that this is where Dave heat stresses the switches. When you get off the elevator you will be greeted by one of Chris' new employees. He is odd looking and usually grouchy. He will be wearing lots of red. The horns and the fork will identify him for sure. I am sure that he will be glad to load you up with a couple switches, IF there is at least a foot of snow and ice on the floor.
Good Luck!
LOL - took me a few seconds after reading it to sink in - THANKS I NEEDED THAT
I heard Chris was sending some gear to Dave so if you can figure out where the UPS truck is, maybe you can divert it.
lligetfa wrote:I heard Chris was sending some gear to Dave so if you can figure out where the UPS truck is, maybe you can divert it.
I was waiting on a box from Mike Calvin which should arrive today then I will send box to Dave.
So that shipment will not go out until tomorrow probably arrive at Dave's Mon or Tuesday
Well... in that case you better check the UPS driver's ID to make sure it isn't amishgenius in disguise.
lligetfa wrote:Well... in that case you better check the UPS driver's ID to make sure it isn't amishgenius in disguise.
Yea, he is a sneaky bastard
Users browsing this forum: No registered users and 71 guests
So wait... if I send you a box, I get a switch?
