Hello,
I bought a Netonix WS-8-150-D to power up 3 cambium force 300 as recommended by a distributor but it did not work, unfortunately I only had access to this ofrum after purchasing.
Does anyone have a model for a DC (12 V input) POE switch that I could use? Please if do so provide me with the complete model
tnx!!
Switch to power up 3 cambiums force 300
- bportilla
Re: Switch to power up 3 cambiums force 300
Have you tryed with Cambium PoE pinout or Tycon cross-poe adapter?
- peremodaw
bportilla wrote:Hello,
tnx!!
Hi buddy, you can use mine for timing in case you still need one.
Regards,
Sloth Smith https://plex.software/ https://tutuappx.com/
