Will PoE power up Aviat WTM 4200?
david.sovereen@mercury.net
Fri Jun 14, 2019 12:23 pm
Does anyone know if the Netonix High Power ports will power up Aviat WTM 4200 radios? Thanks.
Re: Will PoE power up Aviat WTM 4200?
Fri Jun 14, 2019 1:39 pm
I believe it does as this guy uses them (I did a novel concept by using the search feature for posts with the word "Aviat" in them):
https://forum.netonix.com/viewtopic.php?f=8&t=3224&p=28133&hilit=Aviat#p28133
But you can always answer your own question of "will it power this" by following the instructions in this post:
https://forum.netonix.com/viewtopic.php?f=6&t=1178#p8809
