Disable factory reset
sundial
Fri Jun 14, 2019 10:53 am
Is it possible to disable factory reset so customers and competitors can't steal our switches?
Re: Disable factory reset
Fri Jun 14, 2019 12:22 pm
No, this is not a feature and whereas you may think this would be a good feature all I see is thousands of people who disable Factory Default then lock themselves out of the switch and suddenly this would be our fault/problem.
