Is the WS-26-400-AC capable of using a 10gig sfp module? From what I can see, doesn't look like it can. But would like a confirmation and a possible work around, if any. I need to pass about 2 gigs at peak time each night.
10gig sfp
Re: 10gig sfp
Are your SFP+ module capable of running at 1 Gb/s ? Have you tryed the port at both auto and 1G ?
I use DAC+ cable without any problem between netonix switch.
sakita - Experienced Member
- Has thanked: 112 times
- Been thanked: 90 times
Re: 10gig sfp
These are gigabit switches. They'll work with 100Mb or Gigabit SFPs. The max per port is 1Gb.
If you need more than 1Gb of connection LAG is an option.
There is a new product line coming out with 10Gb SFP+ ports.
Re: 10gig sfp
mike99 wrote:Are your SFP+ module capable of running at 1 Gb/s ? Have you tryed the port at both auto and 1G ?
The way I read the OP, he wants SFP+ speed but the switches are not SFP+, only SFP. AFAIK, SFP+ (10 gig) ports are still a future consideration.
mike99 wrote:I use DAC+ cable without any problem between netonix switch.
Good to know that DAC+ cables work. I asked Dave about DAC cables a long time ago but he dodged the question. Linking several smaller port density switches at a location is one way to get more VH ports than one might get with a single larger port density switch.
- bayamon
