Netonix,
Printable views
I need to be able to print pages of configurations for on-site reference and documentation. Currently, the ports are listed on the main page in a sub-frame/div/etc, which causes a problem with printing. If we could select the number of ports shown per page (10,20,all), with 10 as the default (with no subframe), this would be very helpful. (This applies to the main/status page, ports page, and LAGS page.)
Another option would be a "print" view for each page, but I would prefer the former.
Status Page, Sortable Headers
If we could click on a column header and have it sort ascending/descending, that could be useful.
Font
A general font change / size would be nice. Something like Droid Sans ( http://www.google.com/fonts/specimen/Droid+Sans ) seems to look good when I edit the .css, and a reduction to 10pt or so. Something cleaner yet still readable. This does distort some other elements, so those would need to be adjusted to match the font. Playing with the .css in google chrome developer view shows a lot of potential. Is there a desire for the switch UI to match the style of the new login screen? I hope so :)
Edit: Just looking through the .css there's a LOT of different fonts used. If you could settle on two (basically monospace for info, sans for headers and the like) it would probably clean up the design quite a bit.
1.1.0rc19 feedback/suggestions
Re: 1.1.0rc19 feedback/suggestions
You can zoom ( Ctrl scroll or ctrl + / - ) out then print screen to get all ports?
mhoppes - Associate
- Has thanked: 10 times
- Been thanked: 125 times
He speaks the truth... I ran into this the other day. I hand wrote the last three ports :( It is nice to print out to keep at the site.
- keefe007
- keefe007
Every time i use the word font in the presence of my web designer i get an earful!
- Has thanked: 188 times
- Been thanked: 64 times
I think that if you are writing the pay checks, you can call it whatever you want!
