edgeMAX vs WISP Switch
Fri Jul 18, 2014 10:46 pm
The following table does some comparisons.
Magician
Has thanked: 7 times
Been thanked: 31 times
Re: edgeMAX vs WISP Switch
Mon Jul 21, 2014 6:49 pm
Sounds good unless you follow others trends is list something to be supported "yes **** firmware XXX"" and never release :)
Mon Jul 21, 2014 11:41 pm
We chose not to implement MSTP in first release due to time frame and that few people use it.
Do you use MSTP?
If so please weigh in below.
Fri Jul 25, 2014 2:00 am
Here are the official MSRP for the switches. :shock:
I think we did very well building a HIGH quality WISP Switch line in North America not China that is designed for the WISP Industry by a WISP! :mrgreen:
JustJoe
Has thanked: 94 times
Been thanked: 59 times
Sat Sep 13, 2014 11:10 pm
From the environmental specs, maybe you should have named it TougherSwitch ??? Pirate4
amishgenius
Has thanked: 44 times
Been thanked: 45 times
Thu Sep 18, 2014 12:57 pm
There are 2 big differences that make it very attractive to a WISP. 1) temperature ratings are much better suited for the WISPs often install these things. 2) One does not need advanced training in order to operate it. Configuration is very straightforward.
mntpatrick
Mon Sep 29, 2014 4:26 am
How loud is the WispSwitch? Meaning the fans.
Edit: read the specs earlier in the thread. Thats pretty quiet! (i think)
Different models have different number of fans? or they all the same. Are these fans designed to be quieter?
Mon Sep 29, 2014 9:16 am
The 24 ports have 3 fans and the 12 port has 2 fans.
I think they are pretty quiet.
Matt Hoppes and Sam Beiler both saw one here and can confirm they are pretty quiet.
With the fans running at FULL speed which would not occur in a typical room or office with ambient room temperature of 72F it is about as loud as a Cisco 1800 series router.
With the fans at half speed or less in a typical air controlled environment it quieter than a PC fan.
rebelwireless
Has thanked: 31 times
Been thanked: 136 times
Mon Sep 29, 2014 9:34 am
'quiet' brother. it's 'quiet' ;)
mntpatrick
Mon Sep 29, 2014 12:36 pm
Thanks for the info. I'll be preording/ordering one from streakwave. Hope to see them at WISPapalooza.
