Options for troubleshooting spanning tree?
mimbanis
Tue Feb 12, 2019 7:40 pm
Hi All,
Are there any options / commands for troubleshooting spanning tree even if it is just seeing sent / received BPDU's? I have one hop with a Cisco switch running RPVST with a Netonix switch RSTP and 2 links between them 1 Airfibre and 1 Aviat WTM4200 with the WTM set as preferred using STP costs which works elsewhere but not on these links.
Regards
Simon
Been thanked: 210 times
Re: Options for troubleshooting spanning tree?
Tue Feb 12, 2019 10:49 pm
In the cli you can use the command
Code: Select all
show stp
The STP tab in the web UI is also fairly comprehensive.
Wed Feb 13, 2019 1:28 pm
If you want to see BPDU frames, you should mirror the port and look at those with wireshark.
mimbanis
Tue Feb 19, 2019 8:24 am
Hi Guys,
Thanks, bit of a delayed reply. I was afraid I was going to have to mirror the port but was hoping there was a way around it I guess not to be though.
Regards
Simon
