Hi All
I am having issues using a Mikrotik SFP to RJ45 converter (S-RJ01) with the WS-12-250-AC.
It doesn't seem to be passing any traffic through the SFP port, could this be a compatibility issue or
is there a setting perhaps that should be activated in order to utilize the SFP ports on the switch?
Many thanks, hope someone can assit
SFP MODULE COMPATIBILITY
- justfine99
Re: SFP MODULE COMPATIBILITY
Have you test the port both at auto and forced at 1000/full ?
