LACP throughput
vnce
Been thanked: 4 times
LACP throughput
Wed Jan 09, 2019 6:02 pm
So today i was testing 2 mikrotik CCR 10009 bonding 2 ethernet ports in an attempt to pass more than 1 gig through the netonix, I have the bonding and lag working great, the issue I have is when I have the CCR's connected directly to each other i will beable to test a full 2gig,, ie 1.9+gig, when i connect them to the netonix I am only able to see 987mbs through it, as i watch the interfaces on the CCR and on the netonix I see them balancing the load in half on each interface but they will not pass a full or close to 1 gig on each interface. I can unplug 1 leg at any point and the traffic stays at the 987 but passes through the one leg on the side i disconnected from, I hope this makes some sort of sense here.
I am attempting to solve a problem where I have a ws-26 on a site with 22 AP's all negotiating at a gig and of course my total throughput is limited to the 1gig port that is connected to the ccr, I have a 10gig fiber as my uplink on the router so the bottle neck here is the 1gig port on the netonix for these AP's
thanks in advance
Been thanked: 208 times
Re: LACP throughput
Thu Jan 10, 2019 1:44 pm
Can you provide screen shots of your LACP configuration on the LAG page and status page on the switch?
Re: LACP throughput
Thu Jan 10, 2019 3:25 pm
LAG of 2 ports does not create a 2G pipe they create a pipe with 2 1G pipes, you get 2G aggregate not 2G for single transfer.
viewtopic.php?f=17&t=764&p=5675&hilit=+LACP+aggregate#p5675
