First deployment!
mayheart
Has thanked: 48 times
Been thanked: 60 times
First deployment!
Tue Feb 17, 2015 9:16 pm
First Netonix switch has been deployed and is working great.
It's installed in an enclosure on a tower. Fiber ran from the SFP port to the shack inside. Has survived a few nights in -40c weather. (without wind chill)
Impressed so far!
Now the only thing that these things need to do is support 56 volts for Telrad LTE gear. ;)
Re: First deployment!
Tue Feb 17, 2015 9:20 pm
mayheart wrote:First Netonix switch has been deployed and is working great.
Impressed so far!
Well I am not condoning this but the 8 and 12 ports have a potentiometer that you can trim the POE up to 56V and the switch will be fine with it. We just pass through the switch input voltage as the 48V and 48VH.
Of course this would void your warranty. :nono: - I AM NOT SURE IF THAT IS THE MIDDLE OR INDEX FINGER ???? OH WELL EITHER ONE WORKS I SUPPOSE! :rofl4:
We trim the power supplies to 50V so if you VOM the 48V it is actually 50V, is 50V close enough?
adairw
Has thanked: 98 times
Been thanked: 132 times
Wed Feb 18, 2015 12:15 am
We haven't received our Telrad gear yet. But I was under the impression that it was NOT PoE. That you had to run power wire along with the ethernet?
Users browsing this forum: No registered users and 76 guests
