help to make decision
micampo
Fri Dec 14, 2018 2:07 pm
Hello
I will use the DLS-27-15 power source to charge my 24 volt batteries, but in turn feed my WS-12-250-DC swtiche, this device charges me the battery and allows me to supply power to my swtiche when Missing the AC power supply? I am a little confused. (important to clarify that I will not use panels, only the charger and batteries).
Thank you
Re: help to make decision
Fri Dec 14, 2018 3:30 pm
We constantly tell people to hook the SMART DC switches like the WS-12-250-DC directly to the batteries NOT the charging unit.
We recommend an inline fuse or breaker of course between switch and batteries.
Then hook the charger unit to the batteries direct but desperately.
viewtopic.php?f=6&t=4450&p=27007&hilit=+battery+direct#p27007
