UP/DOWN Issues
Andy Hanson
UP/DOWN Issues
Tue Dec 11, 2018 2:34 pm
Good Morning I have three switches I currently run and am always having issues with them going up the down and then being bounced has anyone else had these issues?
THIS IS MY LOG
Dec 1 04:30:58 Port: link state changed to 'up' (1G) on port 11
Dec 1 04:31:18 Port: link state changed to 'down' on port 11
Dec 1 04:31:20 Port: link state changed to 'up' (1G) on port 11
Dec 1 04:37:16 Port: link state changed to 'down' on port 11
Dec 1 04:37:18 Port: link state changed to 'up' (1G) on port 11
Dec 1 13:37:29 Port: link state changed to 'down' on port 11
Dec 1 13:37:31 Port: link state changed to 'up' (1G) on port 11
Dec 1 13:37:34 Port: link state changed to 'down' on port 4
Dec 1 13:37:36 Port: link state changed to 'up' (1G) on port 4
Dec 3 12:33:51 Port: link state changed to 'down' on port 9
Dec 3 12:33:54 Port: link state changed to 'up' (100M-F) on port 9
Dec 3 12:34:12 Port: link state changed to 'down' on port 9
Dec 3 12:34:14 Port: link state changed to 'up' (100M-F) on port 9
Dec 3 13:08:47 Port: link state changed to 'down' on port 9
Dec 3 13:08:50 Port: link state changed to 'up' (100M-F) on port 9
Dec 3 13:09:07 Port: link state changed to 'down' on port 9
Dec 3 13:09:09 Port: link state changed to 'up' (100M-F) on port 9
Dec 3 20:15:42 Port: link state changed to 'down' on port 9
Dec 3 20:15:45 Port: link state changed to 'up' (100M-F) on port 9
Dec 3 20:16:03 Port: link state changed to 'down' on port 9
Dec 3 20:16:05 Port: link state changed to 'up' (100M-F) on port 9
Dec 4 11:51:38 Port: link state changed to 'down' on port 9
Dec 4 11:51:41 Port: link state changed to 'up' (100M-F) on port 9
Dec 4 11:51:59 Port: link state changed to 'down' on port 9
Dec 4 11:52:00 Port: link state changed to 'up' (100M-F) on port 9
Dec 8 12:22:04 UI: Port 5 bounced by admin (10.0.0.25)
Dec 8 12:22:05 switch[790]: Port 5 Link: changed from poe override
Dec 8 12:22:05 Port: link state changed to 'down' on port 5
Dec 8 12:22:23 Port: link state changed to 'up' (100M-F) on port 5
Dec 8 12:22:42 Port: link state changed to 'down' on port 5
Dec 8 12:22:43 Port: link state changed to 'up' (100M-F) on port 5
Dec 8 12:29:46 Port: link state changed to 'down' on port 2
Dec 8 12:29:47 Port: link state changed to 'up' (100M-F) on port 2
Dec 8 13:58:08 Port: link state changed to 'down' on port 5
Dec 8 13:58:16 Port: link state changed to 'up' (100M-F) on port 5
Dec 8 13:58:35 Port: link state changed to 'down' on port 5
Dec 8 13:58:37 Port: link state changed to 'up' (100M-F) on port 5
Re: UP/DOWN Issues
Tue Dec 11, 2018 2:37 pm
Sounds like a lose RJ45 connector.
This was really an issue with AFX radios as they had a jack that did not securely hold the cable in.
We along with many users had to zip tie the cable in such a way as to apply inward pressure on the connector.
Recently at my WISP we had to have tower crews go up and clean some connectors and re-seat them.
But more information would help.
Switch model?
Device on these ports?
Firmware version?
General setup description?
You know, more information to get the guessing game started.
Re: UP/DOWN Issues
Tue Dec 11, 2018 2:43 pm
Also post up a screen grab of the following TABs:
Status, Ports, Deice/Status would greatly help.
Read my post footer for instructions.
If this is an older WS-12-250-AC / WS-12-250-DC / WS-12-400-AC / WS-12-DC and you recently started upgrading radios to higher power demands like AC radios it could be this: viewtopic.php?f=17&t=3934#p24989
Again more information is needed to even try and start to help you.
Example:
I have an wireless link that is dropping out at my WISP, do you have any idea why this is happening?
Pretty hard to help me with that little bit of info.
You would need more info to even begin to help, such as:
Radios
Antennas used if containerized
Firmware
Channel used
Channel width
Co-location of other radios
Competitors in the area
Noise Floor
And the list goes on, the more info the more you could surmise what might be the cause.
Andy Hanson
Re: UP/DOWN Issues
Tue Dec 11, 2018 5:13 pm
I apologize with the pictures I currently do not have print screen I am running off my support machine while I am out in the field office. I will do my best to answer you but can do better once I get back to the office.
Switch model? WS-12-250-DC
Device on these ports? ALL DEVICES ARE ROCKET M5 WITH UBIQUITI AIR MAX SECTORS
Firmware version? v1.19.4 I KNOW ITS OUTDATED BUT HARD TO UPDATE WHEN THE NETWORK IS IN CONSTANT USE
Currently have two AFX on this tower into the switch.
Do you have an email I can email you I cant get these pictures uploaded
Re: UP/DOWN Issues
Tue Dec 11, 2018 5:17 pm
To upload pictures follow the instructions in my post footer.
There is a link called "Upload attachment" by the BLUE submit button
Andy Hanson wrote:Firmware version? v1.19.4 I KNOW ITS OUTDATED BUT HARD TO UPDATE WHEN THE NETWORK IS IN CONSTANT USE
Note sure what v1.19.4 is? Do you mean v1.4.9 ???
You do realize there are security patches in upgrading?
Also we sent out warnings that all SMART DC switches WS-12-250-DC / WS-8-250-DC / WS-26-500-DC NEED to be upgraded to at least v1.5.0 as the APP on the power supply has an issue and can result in BAD things happening.
I run a WISP too but have no issue keeping my switches upgraded?
I use our Manager and schedule them for the evening, usually before I go to bed that way if something goes wrong I get a test message.
viewtopic.php?f=6&t=1549#p11439
ifibra666
Re: UP/DOWN Issues
Mon Jun 21, 2021 7:21 am
Never buy those router they all have problems with port, I have 8 X WS-8-250-AC AND ALL THEY HAVE SAME PROBLEM TIME TO TIME..
Apr 29 06:47:47 Port: link state changed to 'up' (100M-F) on port 3
Apr 29 06:47:53 Port: link state changed to 'down' on port 3
Apr 29 06:47:56 Port: link state changed to 'up' (100M-F) on port 3
Apr 29 06:48:02 Port: link state changed to 'down' on port 3
Apr 29 06:48:05 Port: link state changed to 'up' (100M-F) on port 3
Apr 29 06:48:12 Port: link state changed to 'down' on port 3
Apr 29 06:48:14 Port: link state changed to 'up' (100M-F) on port 3
Apr 29 06:48:21 Port: link state changed to 'down' on port 3
Apr 29 06:48:24 Port: link state changed to 'up' (100M-F) on port 3
Apr 29 06:48:30 Port: link state changed to 'down' on port 3
Apr 29 06:48:33 Port: link state changed to 'up' (100M-F) on port 3
Apr 29 06:48:39 Port: link state changed to 'down' on port 3
Apr 29 06:48:42 Port: link state changed to 'up' (100M-F) on port 3
Apr 29 06:48:48 Port: link state changed to 'down' on port 3
Apr 29 06:48:51 Port: link state changed to 'up' (100M-F) on port 3
May 1 15:38:20 Port: link state changed to 'down' on port 7
May 1 15:38:25 Port: link state changed to 'up' (1G) on port 7
May 1 15:38:26 Port: link state changed to 'down' on port 7
May 1 15:38:28 Port: link state changed to 'up' (1G) on port 7
May 1 15:38:29 Port: link state changed to 'down' on port 7
May 1 15:38:36 Port: link state changed to 'up' (100M-F) on port 7
