Canopy POE Support
ginovilla
Been thanked: 5 times
Canopy POE Support
Thu Feb 12, 2015 11:06 am
Can we get Canopy POE support on the WISP and Tower SW series? its 24 vdc reverse pins , That would expand your market share to Canopy and EPMP users
Re: Canopy POE Support
Thu Feb 12, 2015 4:52 pm
ginovilla wrote:Can we get Canopy POE support on the WISP and Tower SW series? its 24 vdc reverse pins , That would expand your market share to Canopy and EPMP users
Dave and I will discuss this but it will not happen overnight!
LRL
Has thanked: 19 times
Been thanked: 49 times
Thu Feb 12, 2015 11:55 pm
The last Canopy radios I used only support 10/100, if that's still the the case simply change the wiring on one end of your cables or make an adapter that does this.
https://community.ubnt.com/t5/Business- ... 007#M31221
-LRL
adairw
Has thanked: 98 times
Been thanked: 132 times
Fri Feb 13, 2015 12:38 am
I was wondering about ePMP radio's on the WS myself the other day but had not looked up the pin out. I guess there would be no way in software to just say "reverse polarity"?
Fri Feb 13, 2015 12:59 am
adairw wrote:I was wondering about ePMP radio's on the WS myself the other day but had not looked up the pin out. I guess there would be no way in software to just say "reverse polarity"?
LOL - nope, but we are discussing this
So far I have always been PRO Ubiquiti even though it has been a 1 way relationship as of late
adairw
Fri Feb 13, 2015 1:02 am
If it can be fixed by using an adapter cable at the switch or the radio (so it can be labeled as such) I think that would be good enough.
Fri Feb 13, 2015 1:03 am
adairw wrote:If it can be fixed by using an adapter cable at the switch or the radio (so it can be labeled as such) I think that would be good enough.
Yea we can made a little adapter, not the prettiest solution.
You guys might be surprised at what is being discussed right now! Pirate4
Torolan
Been thanked: 7 times
Mon Feb 16, 2015 7:17 pm
Would be great to see the option to power the Canopy gear with an adapter etc.
We are phasing out Cambium gear for the most part, but would be cool to get rid of more POEs at the towers and still have option to reboot these radios remotely.
Mon Feb 16, 2015 7:22 pm
Torolan wrote:Would be great to see the option to power the Canopy gear with an adapter etc.
We can look into an adapter, can you post the pin out, and power requirements here?
Mon Feb 16, 2015 7:33 pm
sirhc wrote:
Torolan wrote:Would be great to see the option to power the Canopy gear with an adapter etc...
My thought was to make the polarity swap in a surge protector. That way you could just swap the guts if you need to change the polarity and the cables stay the same.
Users browsing this forum: No registered users and 86 guests
