change password
JohnWall
change password
Mon Oct 29, 2018 6:57 pm
I know this is pretty basic, but I can't see where I can change the password in the WISP switch. I set it up and installed it in the field without changing the password.
Been thanked: 210 times
Re: change password
Mon Oct 29, 2018 7:02 pm
Once you get access to the UI go to the drop down on that tab to the far right that says 'Device'
Then look for 'Configuration'
Scroll down about bit past half-way and you'll see on the right most column a section called 'Credentials'
You can enter your new password in the 'Password' and again in the 'Confirm' input boxes.
Then save the changes and you're good to go!
JohnWall
Re: change password
Mon Oct 29, 2018 7:57 pm
Thanks for the quick response. I did that and got a message saying 'Invalid fields'.
Re: change password
Tue Oct 30, 2018 9:57 am
JohnWall wrote:Thanks for the quick response. I did that and got a message saying 'Invalid fields'.
Close your browser and re-open or try another browser another computer.
We mainly support Chrome but most browsers should work.
What version firmware are you using?
JohnWall
Re: change password
Tue Oct 30, 2018 10:33 am
Thanks Sirhc
I tired again and got the Invalid fields message again, but noticed several other things seemed wrong, so I rebooted the switch and all is good now.
