I just upgraded one of my switches to 1.1.0.rc13 and see the "Iso" check box on the ports page.
sooo.. I assume any ports that are checked are isolated? Can I also assume that it's tagged and untagged traffic? or is it just the untagged packets on the port?
I really need it on the tagged frames mostly. Can the switch core support something like mikrotiks split horizon bridging? Where you could specify that a port with the same horizon value can't talk to another port with the same horizon value? This way you could control on a port and per vlan what can talk where?
Thanks for the the hard work!
Adair
Port Isolation
adairw - Associate
- Has thanked: 98 times
- Been thanked: 132 times
Port Isolation
Re: Port Isolation
I will have to get back to you on this and the cores ability.
adairw - Associate
Re: Port Isolation
Once I get an answer on what it does to tagged and untagged that will help and will probably be enough to get me going. But I think in the future you'd have to expand on the configuration and possible use a number system like the tik does with SHB or a whole nother page that lists the ports and the vlans so you can select check boxes to define what is isolated.
I wish the switch was here with me so I could do some testing. :)
Re: Port Isolation
I think we may add to the port isolation configuration options?
Maybe make it more like this TP Link implementation instead of the way the ToughSwitch did it.
http://www.tp-link.com/no/article/?faqid=525
adairw - Associate
Re: Port Isolation
Toughswitch has port isolation?
I think that's the same link I sent when I first asked about it. that would do it!
adairw - Associate
Re: Port Isolation
RE the TP-Link config page stuff.
That would work, as long as it also includes the vlans and not the physical ports.
rkelly1 - Experienced Member
- Has thanked: 12 times
- Been thanked: 27 times
Re: Port Isolation
Toughswitch doesn't have port isolation. I'm not familiar with TP-Link options - we use the MT split horizon port isolation and it works great.
Re: Port Isolation
adairw wrote:Toughswitch has port isolation?
Maybe Chris meant EdgeSwitch?
adairw - Associate
Re: Port Isolation
I've never used an edgeswitch, yet so I don't know they had it either. I take it they do? But they still have a lesser operating range and still wont power an airfiber right? :)
Re: Port Isolation
Correct. The ES also doesn't have passive 48V PoE, only 24V. The 48V is only auto af/at. Fine for enterprise stuff but not something I would want for carrier kit.
