WISP 250B connected to Mikrotik CCR (Cloud Core Router)...
billbuchan
Has thanked: 42 times
Been thanked: 34 times
Wed Jan 21, 2015 2:30 pm
I've got a Mikrotik CCR (Cloud Core Router) - the newish white one with the tile lcd display. So far, so good. (It's a CCR1009-8G-1S-1S+, and the CPU usage graph never shows more than 4% utilisation, even with 100 PPP users)
However, I suspect I'm only getting an actual 70mb/s out of the Mikrotik ethernet ports.
Just to stop me going mad - I'm guessing this is a pretty standard configuration - has anyone seen far faster?
And would switching to using the SFP ports help? Or bonding two lines from each?
Many thanks in advance,
Best regards,
---* Bill
http://www.Marykirk.com
keefe007
Re: WISP 250B connected to Mikrotik CCR (Cloud Core Router).
Wed Jan 21, 2015 3:26 pm
You should be able to get nearly 1000 mbps out of those ports.
billbuchan
Wed Jan 21, 2015 4:55 pm
Yeah, thats what I thought too...
---* Bill
Wed Jan 21, 2015 5:08 pm
Bill are you feeding the WS with the MT and then feeding 100M radios?
If so you may need to enable Flow Control on the uplink port and the radio ports?
keefe007
Wed Jan 21, 2015 5:35 pm
Can you explain to us in what situtations flow control is needed? What happens if it is always disabled?
Wed Jan 21, 2015 5:43 pm
keefe007 wrote:Can you explain to us in what situtations flow control is needed? What happens if it is always disabled?
I did answer you about this in another thread: viewtopic.php?f=25&t=420&p=2543&hilit=flow+control#p2543
keefe007
Wed Jan 21, 2015 5:44 pm
I see that now, thanks!
