New switch cant access through SFP?
Mike
Been thanked: 4 times
Sat Sep 15, 2018 8:05 pm
Not sure if I did something wrong or this cant be done but I have 2 Netonix 24 port switches and the first is fed via fiber in sfp (works fine) then the second switch goes from sfp in switch one to sfp in switch 2 so that being said, Can I access the second switch without any cables or devices in the 24 ports but access through sfp only from computer in switch one? I jumped in with cable from switch one to switch 2 and gave it an IP and it all looks good but when I take jumper out and just have the fiber to sfp I cannot get into it. Should I be able to? Its a new switch 1.5 firmware.
Mike
Re: New switch cant access through SFP?
Sun Sep 16, 2018 9:24 am
Try v1.5.1.rc4 as there was some changes that could affect this then let us know.
Please always try the latest code as that is the version in development.
