Recommended BIDI SFP
mayheart
Has thanked: 48 times
Been thanked: 60 times
Thu Jan 15, 2015 1:44 pm
Hello,
I just ordered a bunch of switches. Is there any SFP make people would recommend that would work with these Netonix switch? I've had too many experiences with other vendors and only certain SFPs working.
Thanks.
Re: Recommended BIDI SFP
Thu Jan 15, 2015 1:54 pm
We started this thread, not much info there yet but basically any CISCO compatible SFP "should" work.
viewtopic.php?f=17&t=293
We buy generic SFP modules and they all work but some are crap, when you buy OEM compatible cheap SFP modules it is a crap shoot.
So many people ask manufacturers for a list of SFP modules that work but there are 100s if not 1000s out there and they can not buy 1 or 2 of each and test them all especially us with our limited resources at this point, the best we can do is try and find the ones people report that do or do not work which is why we created that thread but with OEM generics the same SFP module is sold udner many names and brands.
We order 50 Cisco compatible from Amazon and we got like 3 different ones but we thought we ordered 50 of the same because we ordered 1 and it worked well so we ordered 50 and got a mix?
mayheart
Thu Jan 15, 2015 2:02 pm
Thanks!
I'll update that thread with my findings when we get the SFPs in.
