It seems to me the only way a VLAN identifies as QinQ is if one of the ports is labeled "Q".
How do I setup a QinQ pass-through so it comes in one port labeled and out another port labeled? If I just put "T" on the two ports, will it function as a QinQ tunnel, or does it need to know the TPID for this VLAN is intended to be 0x88a8?
Thank you, Chris
How to Configure QinQ Pass-Through?
Re: How to Configure QinQ Pass-Through?
Q on customer ports. T on ports between switchs.
- uberdome
- Experienced Member
- Has thanked: 3 times
- Been thanked: 11 times
I mean, what do I do in the case of a QinQ tunnel going right through the switch (no "customer" ports on the switch)... what then?
Like already writen, T between switchs. Netonix switch only check the outer VLAN.
- uberdome
Like already written, how do I tell it the TPID for this VLAN is intended to be 0x88a8?
I'll just try your suggestion. It sounds like an incomplete implementation if you cannot specify S-VLAN or C-VLAN, but I suppose if it works it works (as long as you don't have overlapping VLAN numbers).
No, you can't specify ether type, the switch T option seem to look only at outer VID, not ether type (or accept both ether type).
Q option encasulate with ether type 0x88A8 while the D (Double VLAN) option encapsulate with the ether type 0x8100.
Not sure what would happen if a S-VLAN and C-VLAN was overlapping but probably a mess lol.
