8-port AC switch - WS-8-250-AC; Firmware 1.4.9
We've been using strict limits on two ports on one of our switches, and I wanted to add additional qos rules based on vlanID. After I added qos rules for both ports, the strict limit values seemed to be either ignored or interpreted differently now. Oddly, after removing the qos rules, the port limit values still don't behave like they did before.
Specifically, port 4 had a value of 130M, which worked as expected previously. Afterward, the same 130M value restricts throughput through that port to 2-3M. I had to increase the value to 1300M to allow more throughput on that port.
Am I missing something, or is this possibly a bug?
Regards,
Mike Kimmick
QoS/Limit Problem
Re: QoS/Limit Problem
Upgrade your firmware which is about a year old or so.
