The specs for the WS-6-MINI say that it will function up to 55 C. I imagine that is ambient temperature? The temp reading shown in Netonix Manager is the board temp it appears. What is the upper limit for the WS-6-MINI. I have had a number deployed in Tycon switch boxes that fit the WS-6-MINI perfectly but they are running pretty hot. I have had a couple of failures possibly due to the heat and, now that I am using Netonix Manager, I am watching the temperature readings. It is a hot day in California today and one WS-6-MINI is reading 66 C, another is 68 C, and another is 74 C. All three are in those small Tycon plastic switch enclosures and two are at the top of towers. Is that too hot for them?
I am moving toward WS-12-DC switches in enclosures but have not settled on an enclosure yet for greater flexibility (powering AF-24HD radios, Fiber and DC up the tower, etc.) but I have not switched out the WS-6-MINI units yet. Should I be concerned?
Temperature Limits of WS-6-MINI
- wirelessblue
- Has thanked: 12 times
Re: Temperature Limits of WS-6-MINI
If you use the search feature you can find a lot of information:
viewtopic.php?f=6&t=2855&p=19698&hilit=+ws6+temp#p19698
- wirelessblue
sirhc wrote:If you use the search feature you can find a lot of information:
Thanks. Apparently I was not searching for the right keywords because I tried that first and did not find those threads. Thanks again.
Users browsing this forum: No registered users and 78 guests
