Recommended screw size for WS-12-250-AC
slimey
Thu Jul 05, 2018 10:32 am
All,
Quick question, not helped by not having a switch within reach to try to measure...
The WS-12-250-AC (and WS-12-250-DC, and presumably others) have two holes through the case for mounting them onto a back-board in a cabinet.
What's the recommended screw size for these fixings?
Many thanks,
Simon
Re: Recommended screw size for WS-12-250-AC
Thu Jul 05, 2018 12:03 pm
I use either a fine thread drywall type screw if attaching to wood or and 8/32 screw bolt if attaching to metal plate or back of plastic box for WS-6-MINI, first I mark the back plate then drill a hole then tap it to 8/32 thread then use an 8/32 thread screw/bolt.
