Powering Security Cameras
Charlie
Has thanked: 5 times
Sun Jun 17, 2018 1:39 am
Has anyone here had any success powering POE 48v security cameras using a netonix switch?
We have some that normally run off 12v but I was thinking about tidying up the wiring at the customer site by using the netonix that is already there. They advertise 48v POE input on the ethernet cable, or 12v via the barrel connector.
Re: Powering Security Cameras
Sun Jun 17, 2018 7:49 am
A lot of people use our switches to power security cameras.
jakematic
Has thanked: 362 times
Been thanked: 87 times
Sun Jun 17, 2018 10:05 am
Just be careful - there is a BIG difference between 48V and 48VH
The latter lets magic smoke out if the device isn't designed for it.
Charlie
Sun Jun 17, 2018 4:09 pm
Awesome, thanks I'll give it a go.
I was worried that one of the official POE formats that the cameras use might be incompatible with the passive POE of the netonix.
Sun Jun 17, 2018 6:10 pm
Charlie wrote:Awesome, thanks I'll give it a go.
Read this post: viewtopic.php?f=6&t=1178#p8809
Sun Jun 17, 2018 8:16 pm
48V work fine with 802.11af and 802.11at devices.
sakita
Has thanked: 112 times
Been thanked: 90 times
Wed Jun 20, 2018 12:54 pm
Always verify the pinout of your particular camera.
For example, some Axis P60 series cameras are different.
Be sure because the magic smoke isn't easily replaced :Cry2:
