Power Supply Calibration
mhoppes - Associate
- Has thanked: 10 times
- Been thanked: 125 times
What exactly does the option to "Calibrate Power Supply" in the DC model do? I can't find any documentation on it.
Re: Power Supply Calibration
Some people complained that the SMART DC units input voltage was not EXACT as there is a +/- tolerance.
So with the SMART DC models you can calibrate the input voltage to be exact.
A quick "search" for the word "calibrate" provides a list of posts that describe exactly what it does.
viewtopic.php?f=17&t=2747&p=19198&hilit=calibrate#p19198
AFAIK it does not affect any switch function. All it does is adjust the reported value to match what you might be seeing from your solar charge controller.
