I have stats box unchecked on a WS-24-400B and the color pie graph still shows traffic like 20% so does the unchecking only stop the the total throughput count or this this a glitch or something? running 1.4.9
Mike
Unchecking stats bok still traffic?
Re: Unchecking stats bok still traffic?
Unchecking stats on a port on the Tab does not affect the color pie chart.
Why would you want it to remove the port from, the pie chart?
Unchecking only stops that port being counted in the the total throughput graph.
v1.5.0 is out
v1.5.0 is out
Ok well that is a vlan from another network going in and out of switch and didn't want it included in this particular situation but as long as total does not reflect that is good. If I had a few ports vlan'd is there a way to combine those for total traffic separate?
Mike
Mike
Interesting I looked tonight and the pie graph didn't show that port traffic at all but when I click port 50 megs are going through so it seems Pie graph is intermittent on showing the traffic in the pie chart.
Mike
Mike
