Fully reboot switch
info@rinkusoluciones.com
Fully reboot switch
Fri Jun 01, 2018 6:21 pm
Hi Guys,
We have been trying to figure out how to fully reboot the switch? I Mean, through the GUI and CLI, you can "reboot" the switching but not the POE completely. Is it possible to restart the switch and devices at the same time ?
Re: Fully reboot switch
Fri Jun 01, 2018 6:33 pm
No, that is a design function.
This allows you to upgrade the firmware and allow the switch to reboot without dropping all your links.
If you want to bounce the POE ports you can click on the little gear on each port row and select bounce port which will power cycle the radio on that port.
Other than that you need to POWER CYCLE the switch to achieve what you want.
