Netonix to power 24v DC not network device
leisser
Sat May 26, 2018 3:20 am
Hello
Can I use two pairs of the netonix port to power a device that does not have a network?
PINs 1, 2, 4, 5 (+)
PINs 3, 6, 7, 8 (-)
In other words, Can I use the port power as power supply only with no data?
Thank you
jakematic
Has thanked: 362 times
Been thanked: 87 times
Re: Netonix to power 12v DC not network device
Sat May 26, 2018 7:24 am
You'd need something like this to step down to 12V since the lowest voltage the switch outputs is 24V
I have several of their 5V converters powering Raspberry Pi devices.
https://www.poetexas.com/collections/al ... poe-12v10w
Sat May 26, 2018 8:30 am
Yes you can but do not pull more power than the POE option you use is rated for.
leisser
Re: Netonix to power 24v DC not network device
Mon May 28, 2018 1:57 pm
Correction....I need 24v not 12v
Im trying to power a Mikrotik CRS317-1G-16S+RM direct to the board that has 110v AC to DC 24v 2.5 Amp power supplies
Can I tie together the pins 1, 2, 4, 5 (+) and 3, 6, 7, 8 (-) to get 24v ?
Thank you
Mon May 28, 2018 6:54 pm
You cannot pull 2.5A via 24VH. The max is 1.5A.
leisser
Mon May 28, 2018 9:34 pm
The Mikrotik PSU is 2.5 A MAX, probably will need 1A max to power the device
Can I connect the wires together?
Tnx
