smtp config with gmail account
- DavidYoung
I have read all I can find on config smtp. Have change to the ports that gmail uses. I get different errors every time. Will it work on a gmail account? If anyone has set it up with gmail I would like to have the config.
Re: smtp config with gmail account
Works for me using secure port 587 smtp.gmail.com
- Has thanked: 362 times
- Been thanked: 87 times
If you have 2FA turned on in gmail you need to add "app passwords" for devices: https://myaccount.google.com/security
*Corrected link and description
