EdgeSwitch supports this, I think EdgeRouter can be "forced" to support it thanks to it's debian base layer, but no other UBNT products do...
Anyway, Radius user auth to login to the device would be a much appreciated feature. I'm getting really tired to not having an easy way to change passwords on *every single network device* when somebody leaves our company (for whatever reason).
Can we get support for this? It's easily supported by the underlying linux system.
Thanks.
FTR REQ: Radius Device Auth
Re: FTR REQ: Radius Device Auth
Radius auth is on the road map.
We also will support multiple users for those that do not use a radius but want to know what employees change in devices.
josh - Associate
- Has thanked: 69 times
- Been thanked: 31 times
Radius w/ remote/local logging would be a godsend.
"20141203 13:22 RADIUS USER: Bob has logged in from: 192.168.10.123 via HTTPS (443)"
"20141203 13:23 RADIUS USER: Bob has requested device reboot"
"20141203 13:28 RADIUS USER: Bob has changed NETWORK from: DHCP-IPv4 to STATIC 192.168.10.20/24"
"20141203 13:33 RADIUS USER: Bob logged out (due to inactivity)"
That is the plan!
