PoE Power Supply:
Passive POE compliant, 50V 1.2A power over ethernet (included)
(https://mimosa.co/products/specs/b24)
Should I use 48 V or 48 VH for Mimosa B24 ?
Mimosa B24
- Julian
Re: Mimosa B24
if their input stage looks anything like the A5 or B5s (Didn't see a pinout on their PoE injector in the documentation you have, but generally Mimosa puts bridge rectifiers on the input), I'd say VH. at 19.5w max power consumption, though, you can safely use 48V, so up to you.
- kfbr
Re: Mimosa B24
We confirmed 48VH works just fine by comparing the pin layouts on the AF24 POE to the B24 POE
Re: Mimosa B24
If you power a device with 48VH and if you have up to date firmware v1.5.0 or newer you can mouse over the watts on the Status TAB and it will tell you if the radio is actually using all 4 pair to pull power.
- whero
Re: Mimosa B24
Yes, 48VH is correct for a B24.
For clarification/evidence, the PoE injector that comes with the B24 is 48V with positive on pins 1,2,4,5 and negative on 3,6,7,8.
