New root
kennaster
Has thanked: 15 times
New root
Wed Feb 21, 2018 1:43 pm
Hello Forum
I keep seeing a lot of these new root log entries on a remote switch. It's a switch that has two roots and several vlans configures. I'm wondering if there is a setting I can configure that will clean this up a bit. I'm currently searching for forum for an example but if the expert users here know of a good example solution, I'd appreciate a link (or literature that might lead to a better understanding of what's happening here). Thanks!
Link to full log: https://www.dropbox.com/s/0s6jrzyn3sy42 ... s.txt?dl=0
Feb 19 18:00:01 switch[816]: Disabling PoE power on port 10 due to Shutdown Period
Feb 19 18:00:01 Port: link state changed to 'down' on port 7
Feb 19 18:00:01 STP: set port 7 to discarding
Feb 19 18:00:01 Port: link state changed to 'down' on port 10
Feb 19 18:00:02 STP: set port 10 to discarding
Feb 19 18:57:09 STP: MSTI0: New root on port 12, root path cost is 400100
Feb 19 19:08:05 STP: MSTI0: New root on port 12, root path cost is 400100
Feb 19 19:08:11 STP: MSTI0: New root on port 12, root path cost is 400100
Feb 19 19:08:17 STP: MSTI0: New root on port 12, root path cost is 400100
Feb 19 19:08:23 STP: MSTI0: New root on port 12, root path cost is 400100
Feb 19 19:08:29 STP: MSTI0: New root on port 12, root path cost is 400100
Feb 19 19:08:35 STP: MSTI0: New root on port 12, root path cost is 400100
Feb 19 19:08:41 STP: MSTI0: New root on port 12, root path cost is 400100
Feb 19 19:08:47 STP: MSTI0: New root on port 12, root path cost is 400100
Feb 19 19:08:53 STP: MSTI0: New root on port 12, root path cost is 400100
These repeat for hours/per day
