Feature Request - turn off poe based on voltage and time
commy
Has thanked: 4 times
Tue Feb 13, 2018 9:11 am
Apologies if this not the proper place to post this request.
It is great to have such a good switch that can turn off the PoE at specific voltage and times - is it possible to provide an option that first checks if the voltage is below a predefined value and then consider the shutdown timers. This is required in the event that you have a solar site with 2 days no sunlight and the banks are getting low, to give the ability to start turning off ports based on time when it hits that lower voltage levels as a first measure.
Thank you
Re: Feature Request - turn off poe based on voltage and time
Tue Feb 13, 2018 9:25 am
This is already supported. :ak:
With the SMART DC switches (WS-8-150-DC - WS-12-250-DC - WS-26-500-DC)
LOOK ON THE POWER TAB
On all switches you can turn off and on POE based on time condition also on the Power TAB.
viewtopic.php?f=17&t=3415&p=22421&hilit=+power+voltage#p22421
Also make sure your running v1.4.9 firmware
commy
Mon Feb 26, 2018 8:57 pm
Yes, but when we fill in the time condition - it always takes effect regardless of the voltage. We would like a toggle that makes it able to first check the voltage and then take into consideration the time ranges.
cbwecomm
Been thanked: 4 times
Thu Jan 21, 2021 3:43 am
This would be a handy feature, for the same use case.
