Prism Gen 2 Power setting?
- webmaster@dasia.net
What POE setting do I use for powering a Prism Gen 2 ?
Re: Prism Gen 2 Power setting?
webmaster@dasia.net wrote:What POE setting do I use for powering a Prism Gen 2 ?
Read this post: viewtopic.php?f=6&t=1178#p8809
"All" airMAX radios use 24V except for one model which was the Titanium which used 48V
Using anything other than 24V on airMAX will result in SMOKE - POOF (Except Titanium as mentioned above)
Just about anything you want to know is available on the forums with a search
Everyone should read the Announcement Threads at the TOP of Each Forum.
I spent hours going through the forums and got a wealth of information regarding this and great discussions regarding grounding and got more confused regarding the Prism (long day). Better to ask and look stupid than to be stupid and not ask, SMOKE-POOF no fun. Thank you very much
Great product! Makes Mimosa B5c's & B11's worth having.
webmaster@dasia.net wrote:I spent hours going through the forums and got a wealth of information regarding this and great discussions regarding grounding
webmaster@dasia.net wrote:Better to ask and look stupid than to be stupid and not ask, SMOKE-POOF no fun.
webmaster@dasia.net wrote:Great product! Makes Mimosa B5c's & B11's worth having.
Groundings recap /tips:
I always add 1 or 2 NEW grounding rods to older existing electrical services and clean up and corrosion
If electrical service ground rods are too far from tower then follow this post:
Make sure you run a heavy #2 ground bonding wire between electrical service ground rods and tower ground rods.
Earth Ground current is the #1 cause of WISP equipment damage NOT ESD and surges.
We also repair UBNT and MIMOSA radios and we see the same damage to those units as our switches when there is poor grounding.
For info on repairing UBNT and MIMOSA radios read this post:
viewtopic.php?f=21&t=2827#p19482
viewtopic.php?f=30&t=2786&p=19279#p19279
viewtopic.php?f=30&t=1816
viewtopic.php?f=30&t=188
viewtopic.php?f=30&t=1429
