Cli Command To Set The Switch To a Static Address
MBBNET
Sun Dec 10, 2017 12:26 pm
What is the command for setting the switch back to static
Whats the command for setting the switch, after being set to static, to a specific address
Thank you guys
Re: Cli Command To Set The Switch To a Static Address
Sun Dec 10, 2017 12:42 pm
These post explain how to get HELP in the CLI to lean all the commands:
viewtopic.php?f=5&t=2469&p=17219&hilit=+CLI+help+cisco#p17219
viewtopic.php?f=6&t=1830&p=13710&hilit=+CLI+help+cisco#p13710
Here are my steps to learn CLI commands wrote: BusyBox v1.19.4 (2017-03-07 13:42:37 EST) built-in shell (ash)
BB-WS1# ? [Enter]
calibrate Calibrate DC input voltage sensor
clear
cmdline Access command line shell
configure Enter configuration mode <= You need to be in COnfig mode
copy Copy from source to destination
exit Exit from EXEC mode
firmware Firmware upgrade
help Description of the interactive help system
ping Send ICMP echo messages
reload Reload system
reset Reset statistics
serial Access the serial port
show Show running system information
terminal Set terminal options
traceroute Execute traceroute
BB-WS1# config [Enter]
BB-WS1(config)# ? [Enter]
accesscontrol Configure access control for the management interface
auto_backup Automatically backup config when changes are made
credentials Set login credentials
discovery Set device discovery options
end Go back to EXEC mode
erps Configure ERPS
exit Exit from current mode
hostname Set system's network name
https-server Set HTTPS server configuration
interface Select an interface to configure
igmp Set IGMP configuration
ip Interface Internet Protocol config commands <= This is where I want to go
ipv6 Interface Internet Protocol V6 config commands
location Supply information about the location of this device
loop_protection Enable loop protection
mac-aging-time Set the MAC table aging time
mirror Set port mirroring configuration.
no Negate a command or set its defaults
ntp Set NTP configuration
pause_frame Enable pause frame protection
power DCDC power supply options
qos Set QoS configuration.
radius Set RADIUS configuration
revert Set revert configuration
smtp-server Set SMTP server configuration
serial Set serial parameters
snmp-server Set SNMP server's configurations
ssh-server Set SSH server configuration
storm-control Set storm control configuration
stp Spanning Tree Protocol
syslog Set syslog configuration
timezone Set system's timezone
vlan VLAN configuration
watchdog Configure watchdog
BB-WS1(config)# ip ? [Enter]
mode Configuration for IP address of management interface. <= THis is what I want to change
address IP address of the management interface (only if mode is set to Static)
netmask Netmask
gateway Gateway IP address
dns1 Primary DNS server address
dns2 Secondary DNS server address
BB-WS1(config)# ip mode ? [Enter]
<dhcp,static> Either DHCP or Static
BB-WS1(config)# ip mode Static <= YOUR ANSWER
MBBNET
Sun Dec 10, 2017 12:55 pm
Very nice answer Chris...
Thanks so much
