Fan failed
David Lee
Has thanked: 3 times
Fan failed
Tue Dec 05, 2017 5:24 pm
My Fan 2 just failed. Fan 1 and 3 are spinning at 8700 plus. Temp outside is 30-50 degrees. Is there an adjustment/upgrade (I'm on 1.4.7 upgrading to .8 this evening) that will cause Fan 2 to restart and take the pressure of Fan's 1 & 3?
Re: Fan failed
Tue Dec 05, 2017 5:32 pm
Firmware usually does not fix Fan Failures.
Fan failures are mechanical failures usually.
Fan can fail from bugs crawling in them and locking them up and sometimes they just die.
You can buy spare replacement fans on our web store: https://www.netonix.com/replacemet-parts.html
