DHCP Snooping
jjonsson
Has thanked: 37 times
Been thanked: 65 times
DHCP Snooping
Tue Dec 05, 2017 11:11 am
Maybe a stupid question, but how and where do I configure DHCP Snooping ?
TorbenRyttersgaard
Re: DHCP Snooping
Tue Dec 05, 2017 11:29 am
It is the DS fields under Ports tab.
Re: DHCP Snooping
Tue Dec 05, 2017 11:34 am
Read this post, not really any config just enable per port
http://forum.netonix.com/viewtopic.php? ... ping#p8168
Also there were fixes to DHCP snooping in v1.4.8 - reference release notes
v1.4.8 wrote:NOTE: IGMP snooping over VLANS, MSTP, and ERPS are still being developed so use these features at your own risk.
FIXED/CHANGED
- Fixed input voltage reading on SMART DC models that may cause false input reading if voltage momentarily drop
- Fixed Changed temp sensor readings on SMART DC models to effect fan speeds
- Fixed SNMP support for Q-SWITCH-MIB, LLDP and CDP
- Fixed IGMP snooping with multiple VLANs
- Fixed DC calibration restarting POE
- Fixed problem with DHCP snooping affecting fragmented UDP packets <========== HERE
- Fixed problem with ERPS enabling forwarding a failed port
- Fixed problem with MSTP setting priority and path cost
- Fixed SSH login with RADIUS when the password contains special characters
- Fixed scheduled port bounce
- Fixed VLAN drag/drop being too sensitive
- Fixed MSTP root message
- Fixed QoS CLI configuration
- Grey out unavailable bulk poe options
- Upper out of voltage range for IDC is now 54V
ENHANCEMENTS
- Added ERPS protocol implementation is g.8032v2 - Ring Protection
- Added BETA note to ERPS
- Added port name to "show interface status" CLI command
- Added an input voltage calibration for DC models
- Improved Q-BRIDGE-MIB support
- Improved fan control on DC models
- Improved stability of ERPS
- Added "Enable Power" action to watchdog
- Added ifMtu to IF-MIB
- Added dot3StatsDuplexStatus from EtherLike-MIB
- Added the time counters were cleared to port detail
- Added watchdog description to email notification
- Added terminal length option to CLI
- Added ability to re-order VLANs using drag and drop
- Enabled IGMP proxy for IGMP snooping
- Added "show igmp" CLI command
KNOWN ISSUES
- IGMP snooping over VLANS, MSTP, and ERPS are still being developed
Released 11/16/2017
jjonsson
Re: DHCP Snooping
Tue Dec 05, 2017 5:58 pm
Thanks...
I'll have to test it out....
